Videorecorder-timer can't build graph with <tune last channel o
Bug in 4.1.1 and 4.1, but clear in 4.0 :
Videorecorder-timer can't start record (can't build graph):
1. If run DVBViewer with <tune last channel on start>=OFF
2. If run DVBViewer with <tune last channel on start>=ON but with command line "-c"
In 4.0 in these cases record was started, if at timers item <disable AV>=OFF.
Bug in 4.0:
If videorecorder-timer item has <disable AV>=ON, videorecorder-timer can't start record (can't build graph):
no bug. Changed behaviour: The timer does not build a playback graph if no playback is active. B)
It's not a bug:
  • Removed: The DisableAV setting for timers is removed. Starting recording timers do not change the current setting of View → Disable Audio/Video in the main window anymore.
There is no need for building a graph for recordings.
If you like to tune a channel us a "Tune Chennel" timer.
But Videorecorder-timer CAN'T START record !!! It's bad behaviour. I work with Task scheduler, It is necessary for me that it was loaded 10 minutes before record. And I do not wish to load the processor these 10 minutes channel viewing (<tune last channel on start>=ON). What to do?
Rename the plugins folder to plugins1 so that no plugins are used. Is the problem then still there?
If the graph is not built, record can't start. It is checked up in practice.
I dont have plugins excluding Netstream.
Edited by Dook
You are wrong, the DVBViewer did not need a playback graph for recording.
Pleas start the DVBViewer with DVBViewer.exe -debug -c and wait until a recording timer starts. Than post your support.zip
