Arabic EPG
Sultanis
I have problem with Arabic EPG, when I select Arabic language in the options it displayed garbage. I can be readable by doing the following steps:
  1. Open the EPG
  2. Export EPG to HTML
  3. Open it in the browser
  4. Change the Page Encoding to Arabic (ISO-8859-6)
I want to find a way to change the EPG encoding to Arabic (ISO-8859-6) to be able to read it in the OSD screens. It seems the current implementation use the Arabic (Windows-1256 )
Here the DVB Specification for Service Information document that describe the Arabic encoding
http://www.dvb.org/technology/standards/a0...0468v1.11.1.pdf
You can't, only I can. That what the test is all about. :)
Thanks,
It will be fixed in the next release of DVBViewer, I have already buy the pro version.
Sultan
I hope it will work in the next version. the whole stuff is anything but simple :) But we're working on it.
