stas35 Posted July 13, 2009 Posted July 13, 2009 (edited) When DVBViewer was in recording mode some emergency shutting down of the PC happened (due to electricity supply interruption) Now DVBViewer starts with REC enabled. Dut RECORD and TIMESHIFT are disabled in options. Impossible to open some channels. Every time a message arrives RECORD/TIMESHIFT is enabled etc. After reinstalling DVBViewer the problem still exists. Is there any solution except of uninstalling the program for ever ? Thank you in advance! Edited July 13, 2009 by stas35 Quote
Lars_MQ Posted July 13, 2009 Posted July 13, 2009 close the DVBViewer go to the configuration folder and rename the timers.xml. Quote
stas35 Posted July 13, 2009 Author Posted July 13, 2009 (edited) Thank you! Hopefully it will help What does it mean "rename"? Should I create a new file with name timers.xml ? Edited July 13, 2009 by stas35 Quote
Griga Posted July 13, 2009 Posted July 13, 2009 Rename means rename. Give it a different name, so DVBViewer doesn't find it anymore (as if deleted), but the file isn't lost in case you want to revert to it. Quote
