Dook Posted July 14, 2009 Posted July 14, 2009 (edited) I have two copies DVBViewer installed in different folders. How through OLE to get access to both started copies DVBViewer? GetActiveObject gives the reference only on a copy started by the first. Edited July 14, 2009 by Dook Quote
Tjod Posted July 14, 2009 Posted July 14, 2009 It is not possible to accesses more then one installation via COM Interface. But one installation is able to handle more then one TV card. And pleas stop Crossposting: § 4 Do not post the same topic in multiple forums. If you are unsure of which forum a thread should go under, just state that in your post, and a moderator will move the thread to the correct forum. Multiple posts are unnecessary and will be deleted. It is also not allowed to post the same question multiple times in multiple threads in the same forum. http://www.DVBViewer.info/forum/index.php?act=boardrules Quote
