evgen_ln Posted July 17, 2009 Posted July 17, 2009 Unfortunately I don't see any way to receive number of the currently used tuner. Could you add function like this: function CurrentHardware:Integer; for use together with function HardwareName(Card: Integer): WideString; function SignalErrorRate(Card: Integer): OleVariant; function SignalQuality(Card: Integer): OleVariant; function SignalStrength(Card: Integer): OleVariant; Value of the functions SignalQuality and SignalStrength is equal (TwinHan 1041, TT S2-3200), is it possible to correct it? Quote
Lars_MQ Posted July 19, 2009 Posted July 19, 2009 You have 5 cards, one mainplayback, 3 recordings and PIP running. which is the current hardware? Quote
Valts Posted July 19, 2009 Posted July 19, 2009 You have 5 cards, one mainplayback, 3 recordings and PIP running. which is the current hardware? mainplayback naturally. Same one the OSD shows information for. Quote
