Bug on ZDF HD Astra 19
Etienne
I have some trouble concerning this transponder on :
Astra 1F (19.2E) - 11361.75 H - Txp: 11 -DVB-S2 (8PSK) - 22000 2/3 - NID:1 - TID:1011
It includes new channels ZDF HD and ARD HD and old ones (ARTE + 1 test).
With transedit 3.3.3, all works, and preview works for all 4 channels in HD.
So i returned in DVBViewer (3.9.4.0) , and scan the transponder.
It found the new channels in scan..
When i select old channels from transponder (ARTE or test channel) all is still OK
But when I select one of both new channels, DVBViewer blocks, i can't do anyting whit it after..
Only solution is to go in setup.xml and remove the "LastSender" line ..
Any Idea ?
update to the current versions. no support for old versions.
I have updated to latest version 4.1.1.0 and yes it works !
I diden't update at each release when it works ... :biggrin:
Thanks for quick answer
Etienne
