blasgl Posted July 20, 2009 Posted July 20, 2009 I would like to have updated EPG Data available on the Web Interface wenn I am away for a couple of weeks but it seems the automatic EPG Update runs only when the service is restarted. I have configured my PC to switch between "On" and "Stand-by" states when being away from home. Is there a way to trigger or schedule an EPG update from the Web Interface? Thanks in advance for any hint, Quote
Lars_MQ Posted July 20, 2009 Posted July 20, 2009 Create a internal task and then look in the webinterface on the page timers -> tasks. Quote
blasgl Posted July 21, 2009 Author Posted July 21, 2009 (edited) I´ve created a EPG Update Start task and the manual execution works fine. Have two questions though: 1. Do I need a EPG Update Stop task in any case? Or does the EPG update stop automatically once finished? 2. When I try to create a "process task timer" the "task" drop-down list is empty. Any clues? Edited July 21, 2009 by blasgl Quote
Lars_MQ Posted July 21, 2009 Posted July 21, 2009 1. No you don't need it. It stop automatically. 2. http://en.DVBViewer.tv/wiki/Timer_concept_...e#Process_Timer Quote
blasgl Posted July 21, 2009 Author Posted July 21, 2009 ok, no "Internal Task Timers" then... Thanks Quote
