Mute, channel export and recording modes
Thomcat
I'm a regular user of DVBViewer and here is a couple of ideas I have.
Mute option in DVBViewerS.exe should mute DVBViewer only not whole system
and only temporary. I'm not sure if this is for DVBViewer or DVBViewerS.exe.
It would be nice if one could export ALL channel IDs at once to a file
(eg 1126236569|Discovery) instead of one by one.
Some channels use Teletext for subtitles and the only way to record
subtitles is with .ts files. Why not implement a couple of preset
recording modes, channel by channel. If you don't select anything
it will use the default mode. If however I've selected one particular
channel to use another preset mode it will use that.
You could choose Use .ts file and which streams to record
what's DVBViewerS.exe?
It's a Commandline Starter Plugin. You can find it in member section
Thomcat
DVBViewer -> Setting -> DirectX -> Audio -> Audiorenderer -> Default Directsound Device.
Well use TS as default. It's anyway the best and most flexible recording format to use.
Thats no solution. Most channels I record does not use Teletext subtitles. It's already
overlayed on the picture, not removable. To record in TS is somehow overkill for those channels.
TS is far more difficult to cut/edit than mpg so I use mpg as much as I can.
And for the sound settings I have Default Directsound Device... ;)
