DVBViewer 4.2.1's Timeshift...
antdude
This is only a recording if you feel the need for recording during timeshift. Its nothing you want for normal programmed recordings.
This will lock you on the channel you watch/timeshift for the entire recording time. :bye:
Oh, even if I have more than one HDTV tuner cards? Darn.
Well a timeshift recording is tied directly to timeshift. It uses the timeshift file as "DVB streamsource". Otherwise it would obviously not work. And there is no way to change seamlessly from the filesource to a dvb device source at the "end" of the timeshift file.
For what exactly do you would have this option in timers? What should this do what the others dont?
