Benarty Posted July 27, 2009 Posted July 27, 2009 I've installed DVBViewer 4.2.1 yesterday, without overwriting the channel list, no plugins used. DVBViewer 4.2.1 works great, far stable. I got lock up's of the audio driver when zapping too much in the OSD menu but that problem is suddenly gone so far. But TV vlaanderen did some changes so had to scan again and this caused some weird problems. Frequency scan nothing found. If I scan the entire astra 19.2E then the floppy DTV-S2 should find several hunderd channels but in this canse none = zero. Except: The channel scan updates existing channels. I can whatch and record without any problem channels in the existing channel list, both encrypted as FTA. But scanning even new FTA channels doesn't work. No support.zip yet cause setup did not change at all, just DVBViewer. And yes, restart windows , digital everywhere app (which is sort DVBViewer version) works great, so can scan. Perhaps cam related? No cam problems after the mediaguard 3 change If i switch back to the older DVBViewer version, then scan finds all channels. Is the scan routine in DVBViewer 4.2.1 changed? if so, then I stay with the previous version. Support.zip: I know but this is DVBViewer related with version 4.2.1 and will post support.zip asap. Quote
Lars_MQ Posted July 27, 2009 Posted July 27, 2009 http://www.DVBViewer.info/forum/index.php?showtopic=35263 -> Scanwindow. You should know by now, that you have to read the changelog carefully. Quote
