Chinese EPG Problems in 4.2.1
Gary Lam
Yes that's to be expected. Simply put: EPG is Unicode, timer/channels isn't complete.
And I tell you secret: This release was probably the last ansi release. There is already a unicode beta waiting, where a lot of problems are addressed. Not all, as I stated in the answer to the beta report, because there are several things to be taken into consideration (especially channels/timers/favourites). But what does work: drag'n'drop of unicode media files, display of unicode through out the OSD pages(video/images/music), commandline, playlist including id3 v2 tags etc. it requires quite some changes and I do have to be careful not to break too much for the ANSI users... ;)
When we can see the new version? Also, can you put back the 4.1.1 for downlaod?
And I tell you secret: This release was probably the last ansi release. There is already a unicode beta waiting, where a lot of problems are addressed. Not all, as I stated in the answer to the beta report, because there are several things to be taken into consideration (especially channels/timers/favourites). But what does work: drag'n'drop of unicode media files, display of unicode through out the OSD pages(video/images/music), commandline, playlist including id3 v2 tags etc. it requires quite some changes and I do have to be careful not to break too much for the ANSI users... :bye:
It's a great news~
Thanks
