teetee Posted July 31, 2009 Posted July 31, 2009 On one PC ("recording PC") I have set up the Settings-Options-Recorder Directory to be a shared directory on the recording PC. In another room, I need to set up another "playback PC" with DVBViewer, so that it uses that shared directory as its recordings folder. However, even if the Settings-Options-Recorder Directory of both PCs points to the same shared directory, the recordings are visible only on the recording PC. I have looked both via DVBViewer-Recordings Statistics-Recorded shows and the OSD Recordings page. Is there a solution to my need? How can I share the recordings done in one PC with another PC? Can DVBViewer somehow refresh its list of recorded shows just by reading the contents of the recordings directory? Thanks /teetee Quote
Tjod Posted August 6, 2009 Posted August 6, 2009 Change the shortcut to ...\DVBViewer.exe -x8260 Quote
