Bobben Posted August 4, 2009 Posted August 4, 2009 I have been away from this forum for a while and I'm just wondering if the Technotrend USB S2-3650 CI supported now by both DVBViewer and TransEdit ? Technotrend also now provides has a similar USB card which supports both DVB-C/DVB-T and comes with CI support. The Technotrend web is down at the moment so I'm not sure what the model number is. Does anyone know if this works with DVBViewer and TransEdit ? I am mainly using Transedit and S2-3600 card without CI. Would have been great to be able to record descrambled streams. Quote
Griga Posted August 4, 2009 Posted August 4, 2009 Technotrend USB S2-3650 CI supported now by both DVBViewer and TransEdit ? Should work. http://www.google.com/search?q=TechnoTrend...=DVBViewer.info For TransEdit the 3600 and 3650 are just the same, because it doesn't care about CI. Quote
Bobben Posted August 4, 2009 Author Posted August 4, 2009 (edited) Should work. http://www.google.com/search?q=TechnoTrend...=DVBViewer.info For TransEdit the 3600 and 3650 are just the same, because it doesn't care about CI. Ok excellent news. I will order asap :-) I also hope the limitation of total bitrate has been corrected in the 3650. It has been corrected for 3600. 66Mbps works well now in 3600 while tech data for 3650 at DVBShop.net states max. totalt bitrate of 60Mbps As I understand the C&T version of the 3650-CI will also work in DVBViewer/Transedit ? Edited August 4, 2009 by Bobben Quote
