sysman Posted August 5, 2009 Posted August 5, 2009 Hi. I am running Vista 32 Ultimate, fully patched, DVB-Pro V4.2.1.0, Intel Core Duo 3Ghz, 3Gb Ram (OCZ Reaper 1066) & Nvidia 9800GT. The Tuners I use are Hauppauge Nova-T PCI & Compro VideoMate S350 PCI. The problem I have got is that when I view BBC-HD or Luxe TV HD in DVB-S I can not get the picture to fill the screen, I have tried various resolutions, but the picture is always smaller and has a big black border round it. Regards. Andrew Quote
Brunhilde Posted August 7, 2009 Posted August 7, 2009 (edited) I am running Vista 32 Ultimate, fully patched................. Patched, cracked, warez & Co, concepts, that prevent a helping answer in the forum, should be surely. There, also a legal DVBViewer version alters nothing at it. Edited August 7, 2009 by Brunhilde Quote
Tjod Posted August 7, 2009 Posted August 7, 2009 I think "fully patched" = all updates via Microsoft update installed. Quote
sysman Posted August 7, 2009 Author Posted August 7, 2009 I think "fully patched" = all updates via Microsoft update installed. Correct, thats exactly what I mean by fully patched. Thankyou for pointing that out to the other member. Quote
Devastation Posted August 7, 2009 Posted August 7, 2009 till a solution is found you could use the zoom funktion in DVBViewer. This will do the job I hope? Quote
sysman Posted August 7, 2009 Author Posted August 7, 2009 till a solution is found you could use the zoom funktion in DVBViewer. This will do the job I hope? Hi. Thanks for the reply, tried that, did not work. The image is justified to the left hand of the screen, so when you manipulate it using the zoom tool some of the image is chopped off, its strange! Quote
Devastation Posted August 7, 2009 Posted August 7, 2009 Yes, I read about this. Its the Nvidia afaik. Try different renderers (Overlay VMR EVR) See in Options --> DirectX if there are the checkboxes VMR fix. If so check or uncheck for testing. And do this with the different renderers. Maybe you can solve it this way. Quote
