leo1971 Posted August 6, 2009 Posted August 6, 2009 Hi guys, There is no Hardware section in english part, just on Deutsch. (i do not undertand deutsch, and google translate is not good). All players was working, then I installed sp3 in my windows xp 32bits. Skystart hardware rev 2.6 Now DVBViewer, progdvb, tsreader do not work. Mytheatre, alt-dvb, dvbdream is working. I tried with all drivers from skystar and b2c2, and bda drivers. not changed. same results. I do not want uninstall sp3, is there other solution? On google transalate i read on deutsch section something about power managemmente, i turnned off, but nothing changed. I tried install all last uptodate from windows, but nothing change. Could someone help me, please. Best regards Quote
Tjod Posted August 6, 2009 Posted August 6, 2009 Have you installed the current diver and TechniSat application? Pleas post your support.zip Quote
leo1971 Posted August 6, 2009 Author Posted August 6, 2009 (edited) Have you installed the current diver and TechniSat application? Pleas post your support.zip Yes, I installed last 4.5.0 driver and all from last 2 years, no one works. What is technisat application?Is It dvbviewerTE? I installed DVBViewer PRO 4.2.1. Thanks in advance. support.zip Edited August 6, 2009 by leo1971 Quote
Tjod Posted August 6, 2009 Posted August 6, 2009 There are some file missing on your System you have to run the setup in the Technisat Driver packet. Quote
leo1971 Posted August 7, 2009 Author Posted August 7, 2009 There are some file missing on your System you have to run the setup in the Technisat Driver packet. DVBViewerTE is a confuse name because it is DVBViewerTE togheter with driver packet. I just run setup DVBviewerTE like you said. All working again, thank you very much. Quote
leo1971 Posted August 8, 2009 Author Posted August 8, 2009 About subtitle, same solution. I was only changed driver directly at DeviceManager. And i had deleted that humble dvbviewerTE. maybe this was the problem... ...in my other micro (intel - skystar HD) now working too. Add: Added support for plain text DVB Subtitles. Add: Added support for 2 bit DVB Subtitles. it works. 4.2.1.0 PRO last final release ok for subtitles. just run setup too from confuse name dvbviewerTE, to work with DVBViewer PRO. Thanks again... Thanks. Quote
