Status bar
Clément Leblanc
Hello,
Is someone could explain me what does it mean the "star" near the current channel name in the status bar.
I have some problems since the frequencies changes for bis TV on Atlantic bird 3. Some channels on transponder 11554 like TF1, M6, W9 and NRJ 12 give me a black screen, all the other channels are working fine.
With the channels that not work, I have the like star symbol near the channel name in the status bar.
Manyy thanks for your help.
FloppyDTV DVB-S2
Red Viaccess cam
DVBViewer 4.2.1
The star mean, as far as I know, that CAM/CI are not able to Decrypt this channel.
Thanks for your help.
Do you know which is the best viaccess module (pcmcia) for DVBViewer ?
