scanya Posted August 8, 2009 Posted August 8, 2009 I'm using DVBViewer to watch polish terrestrial DVB-T channels. EPG works almost OK - DVBViewer shows incorrectly some polish national chars. These chars are OK: ć ę ł ń ó ż Ć Ę Ł Ń Ó Ż But these are showing incorrectly: ą => ± ś => ¶ ź => Ľ Ą => ˇ Ś => ¦ Ź => ¬ I checked this and problem is wrong chars coding. DVBViewer uses east europe windows (Windows-1250) coding for EPG, but correct coding is east europe iso (ISO 8859-2). I create simple html file: http://scanya.republika.pl/epg_polish_dvb-t.html If I open it in web browser (I use IE7) and I set "coding / east europe (windows)" - some chars are wrong. But if I set "coding / east europe (iso)" - everything is OK Can you correct this problem ? support.zip Quote
