Help for beginner
sentio
Hello,
I am beginner.
I want to stream transponder.
I use DVB Recording Service for Stream to LAN (web interface)
When i ddnt choose Direct Connection cant get any stream
When i choose direct connection there is stream (with .ts extension url)
Unfortunally .asx extension cant work i set port 5600 for stream and open this port (i checked with pfportchechker)
stream url is http://192.168.1.4:5600 but cant work
what is wrong with this
thanks
You can't stream the complete transponder with the recording service. It does only stream on request, because of the bandwidth requirements. To transcode while streaming you need to install vlc 0.8.6i. The newer versions of vlc are buggy and don't work.
Hi this stream for LAN not internet thast why we dont have bandwith problem
and i have to run view with internet explorer embeded
thats why i need to asx
thanx
