New recording behaviour: on-screen menu
ml 05019
Hello,
I've updated recently to DVBViewer version 4.2.1 from 4.1.1
in the previous versions, there was a recording behaviour that you can start and stop the recording with a single press of the ® key on the keyboard. There also was a menu with recording options available by clicking the record button with mouse while recording.
Now, in version 4.2.1, the menu pops out both by a mouse click, and by pressing R on a keyboard - as it's an on-screen menu (the author would probably know the best what I'm talking about).
the question is - how do I disable that new on-screen menu and be able to stop the recording with a single press of a key? I guess some people may find this new menu useful when they don't use the mouse, but I'd like to have a setting to disable it, because if I can't stop the recording immediately, the recordings are longer, and it consumes my hard disk space with the videos I don't need.
So, is there such a setting, or should we wait for it in a future versions? Thanks in advance.
Regards,
ML
(Until this happens, I've rolled back to version 4.1.1 for now)
Maybe I will someday,
but still I'll have to press two buttons to stop the recording, not one as before o:)
and one more thing:
the 2nd item in that menu is "play" and it plays the recorded file while it's still recording in the background. Maybe you could duplicate this item - make another command to "stop recording and play"?
Edited by ml 05019
