Liquidator87 Posted August 10, 2009 Posted August 10, 2009 As title says... Can I force the program to use the installation directory instead of the one in %APPDATA% to save his settings? Quote
Griga Posted August 10, 2009 Posted August 10, 2009 Edit the file UserMode.ini. Set UserMode=0. I hope you know what you do because MS doesn't want you to do it. Quote
Devastation Posted August 10, 2009 Posted August 10, 2009 (edited) MS is the manufacturer of your operating system http://www.DVBViewer.info/forum/index.php?...st&p=150777 Edited August 10, 2009 by Devastation Quote
Tjod Posted August 10, 2009 Posted August 10, 2009 e.g. if you use Vista and UserMode=0 don't save DVBViewer in C:\Program Files Quote
