uyguremre Posted August 12, 2009 Posted August 12, 2009 Hi I am using DVBViewer 4.2.1 with Skystar HD2 . I am using it as HTPC where I almost exclusively use OSD menus . My remote (that comes with skystar hd2) works as a keyboard . OSD up and down are mapped to keyboard up and down which is normally channel up and down on osd (default skin) . I want to use the auto-time shift function but there is a problem. Once timeshift is active when I press up nothing happens and when I press down it pauses. I can than only change channels buy inputting channel number which is not very convenient. Is this a bug or is there a workaround for this? Quote
godik Posted August 12, 2009 Posted August 12, 2009 This is not a bug. To get the "TV default" behaviour with timeshift enabled you have to configure some stuff on your own. In the remote section, you'll have to define new commands (with own command codes) for the following : OSD - up OSD - down OSD - left OSD - right OSD - green The eventcodes codes should be greater 30500. Now, after you have done this, you have to configure what should happen if this new event codes occure. This will be done in the command.vbs you'll find under scripts. If it does not exist, create one. It is a simple text file. Be aware, that sendcommand(20) and (21) are for favorites in my config. If you'll use channel +- you'll have to use the channel +- codes, which I don't have in mind. Change the command.vbs only while Viewer is shut down. Here you'll see my command.vbs sub main(ActionID) Select Case ActionID Case 30501 'for OSD-Green If osd.isVisible Then SendCommand(75) ElseIf istimeshift Then SendCommand(8197) Else SendCommand(75) End If Case 30504 'for OSD-left If osd.isVisible Then SendCommand(2000) ElseIf isMediaplayback Then SendCommand(112) Else SendCommand(2000) End If Case 30505 'for OSD-right If osd.isVisible Then SendCommand(2100) ElseIf isMediaplayback Then SendCommand(113) Else SendCommand(2100) End If Case 30506 'for OSD-up If osd.isVisible Then SendCommand(78) ElseIf istimeshift Then SendCommand(21) Else SendCommand(78) End If Case 30507 'bei OSD-down If osd.isVisible Then SendCommand(79) ElseIf istimeshift Then SendCommand(20) Else SendCommand(79) End If ' Case Else ' osd.showInfoinTVpic "No action in the Command.vbs for the ActionID " & ActionID,1000 'Zeige die Text Information No action in the Command.vbs for the ActionID (ActionID) 'für 1000 Millisekunden im DVBViewer an. End Select end sub Quote
Tjod Posted August 15, 2009 Posted August 15, 2009 Or open the setup.xml in the Configuration folder and add in the <section name="OSD"> </section> <entry name="TimeshiftEPGdisplay">1</entry> http://en.DVBViewer.tv/wiki/Tweaks Quote
