Error!
Does this just mean I have entered my user data incorrectly?
I keep re entering it and running the program as administrator on windows 7.
Anyone got an idea how I can fix this problem?
I think this info text should be changed. There's no use of starting the app as admin if you have this error - to fix it, you have to reinstall the app entering the correct userdata
As far as i know, this message is not from the current version 4.2.1.
