VeePee Posted August 18, 2009 Posted August 18, 2009 (edited) MSE reports that svcoptions.exe and dvbvservice.exe are infected by Induc.A. Also 5 other reports suspicious file at virustotal: http://www.virustotal.com/analisis/51fdc07...bd1c-1250624551 Is this false positive? Hopefully.. edit: installed package was svc_setup_1.5.0.31.exe and file sizes: DVBVservice.exe 512 093 bytes svcoptions.exe 379 997 bytes Are these sizes what they should be? Edited August 18, 2009 by VeePee Quote
Tjod Posted August 18, 2009 Posted August 18, 2009 This time it is a Virus. But download it again, there is no Virus any more. Quote
hackbart Posted August 18, 2009 Posted August 18, 2009 Well depends on the definition. The attached zip contains a tool for delphi programmers who got in touch with this kind of plague. If you do not use Delphi, there is no need for getting scared. If you do, feel free to use this tool. The viral code luckily does not contain any malicious fragments, but it definitively points to problems which should, and will be kept in mind by us. Christian delphifix.zip Quote
Moses Posted August 18, 2009 Posted August 18, 2009 (edited) For the german readers: http://www.heise.de/newsticker/Virus-infiz.../meldung/143679 Short explanation for english speakers: The virus infects delphi, a development tool, which is also used for DVBViewer, and infects every program that is produced with this infected tool. The virus does not contain any code that harms a system. In fact, on systems that don't have delphi installed it does not do a thing. Delphi programers should be aware and check their delphi version (for example with the tool provided by hackbart). Just to easy the panic a bit. PS: oops, I didn't see the link to the english article: http://www.h-online.com/security/Virus-inf...t--/news/114031 Edited August 18, 2009 by Moses Quote
avoidz Posted August 19, 2009 Posted August 19, 2009 Should I be worried about this as a regular DVBViewer user (version 4.2.1.0)? Quote
Griga Posted August 19, 2009 Posted August 19, 2009 Should I be worried about this as a regular DVBViewer user (version 4.2.1.0)? No. I've checked it here (all executables of DVBViewer Pro/GE installations, TransEdit, TSPlayer and various Add-Ons), and it's clean. Quote
