How to install osd skin
master44tr
Hi everyone!
I downloaded and tried several osd skins from customer area, but I can't apply them. I put the osd folder C<program files<DVBViewer<osdskins next to the default folder. I start DVBViewer options<osdskin and see my new osd skin and choose it and apply, but I only see the same skin. Default skin.
I use DVBViewer 4.2.1.0
Thank you!
check if in the OSDSkinfolder is directly a image-folder and .xml files.
Some Skins are in a mainfolder that will have the skinfolder.
eg. -DVBViewer\OSDSkins\SkinXY\dialogOK.xml
is correct
DVBViewer\OSDSkins\SkinXY\SkinXY\dialogOK.xml
is wrong.
I uninstalled 4.2.1.0 and installed 4.1.1. Everything seems normal, but osd doesn't change.
If you have a problem in 4.2.1 I can may be see something in the support.zip from 4.2.1
Okey, thank you very much for your interest.
I know there is a trick but I can't find it.
Sorry no real idea. There is nothing in the log files and the configuration looks OK.
Only one thing if you have a second Vista user, login as the other user and check if the Skin is there in the DVBViewer folder
If not check if there is a DVBViewer folder in.
C:\Users\[username]\AppData\Local\VirtualStore\Program Files
Yes, it is in the DVBViewer folder. But there is no C:\Users\[username]\AppData\Local\ VirtualStore\Program Files
Thank you, tomorrow I will try it
