DVB Viewer recording service (task bar based)
diddy
I used to have a plug in that ran when DVBViewer was turned off but was wondering if it is still available.
I remember the add on was an exe file that had to be placed in the DVBViewer folder and a short cut was made to the windows start up folder.
This then ran when the user logged in.
I am sorry but I cannot remember the name of the extra add on.
What I was looking for was a task that ran and checked for scheduled recordings.
When a recording was set DVBViewer would open up and run with the volume muted and then record a scheduled recording.
Then once complete DVBViewer would close.
The DVBViewer is a bit overkill for what I need.
If anyone could help that would be great.
At the moment I have to manually start DVBviwer before a recording is set then mute the volume and then minimise the software
Dont worry. panic over
I eventually found it.
Its called 'Scheduler.exe' and allows the user to run up DVBViewer minimised and also what action to perform after recording.
Why is this software not available to download anymore ?
I had to search my server for it (fortunately I back up data)
