C# or VB.NET plugin template
nickbeat
I'm not into Pascal/Delphi but I want to develop a plugin for DVBViewer. My Idea is, to make use of the XMBC MyMovies.db to show my videos like the mymovies-plugin for DVBViewer. I can't use the mymovies plugin 'cause my movies are stored as single files in one folder witch is not supported by the DVBViewer-MyMovies plugin.
The COMInterface does not include the IOSDWindowManager.NewWindow function so I need to use a iInterface:Unknown like the Pascal-plugin myprograms.
I found a website that explains how to use delhi in C# but I'm not so deep into the C# language.
website: http://www.delphipraxis.net/topic160710.html (german)
May someone can post a template/plugin that makes use of the interfaces that are not in the COMInterface.
You need to translate the uplugininterfaces.pas to C# or VB.NET.
I guess that there are more people that would like to do some plugins but are not into Delphi/pascal...
Thanks for the support
NickBeat
Real Plugins must be Real DLLs (as in C or Delphi dlls). C# and VB.net can't create these.
