Userdata.xml
arc03
Hi all.
I have a problem.
I tried to edit userdata.xml. I opened DVBV, went to "Help" -> config.folder -> open userdata.xml to edit -> save the edited data -> DVBV closed and opened again but when I check the userdata.xml, all edited parts are gone.
I know it should work because I done it earlier, but why doesn't it work now?
And should it be done each time I get the new version of DVBV??? Because when I upgraded to newest DVBV, the last edited userdata was disappeared.
just close the Viewer before you edit.
Thank You.
