the vaporizer Posted August 29, 2009 Posted August 29, 2009 After updating to V4.2.1 all pay-tv channels no longer get discrambled. CAM menu shows just fine, EPG shows up. but no screen/audio. Also in the menu status bar it shows the channel name with a star(no key found?). So i installed V4.0 back and it descrambles just fine. All FTA channels work fine in both versions. Ay idea's ? support.zip Quote
the vaporizer Posted August 29, 2009 Author Posted August 29, 2009 No, exactly the same problem. FTA works fine. no paytv Quote
the vaporizer Posted September 13, 2009 Author Posted September 13, 2009 I have some additional information I hope this would be of any help to find out where the problem is. I have a astoncrypt V1.05 with a canaldigital smartcard. When I watch FTA channels every thing works like expected, however when I try to view a canal witch is encrypted and I don’t have the right to watch it; it pop’s up a message saying “no right to watch this program”. When I want to watch a channel from canaldigitaal it does not say “no right to watch this program” it just pops-up the mini EPG like usual with the EPG showing. The screen stays black and no sound. When I go to the properties of the filter called “DVB Source” it says “video state: no data / connected”. I hope this helps Quote
the vaporizer Posted October 4, 2009 Author Posted October 4, 2009 Some news; canaldigitaal send me a new smartcard. The alphacript CI module did not handle the new smartcard so i orderd a new CI module: mediaguard this is a signed module for canaldigitaal. Installed the new module and i got picture with the older version V4.0. because i had a hardware change i agian tryed the new V4.2.1 and guess it worked! well i thought so... most channels work but some channels like "discovery" it says "no right to watch this progamm". When i downgrade to V4.0 it does decrypt any idea's ? Quote
