TommyN Posted August 29, 2009 Posted August 29, 2009 Hi, I'm using DVBViewer Pro and I would like to access the data that is displayed in the Telext window (File-Teletext) without having DVBViewer up and running. What I would like to do is create my own application where I can display the teletext. Does anyone here know how to go about doing this? Any pointers would be greatly appreciated. Cheers, -Tommy Quote
Griga Posted August 29, 2009 Posted August 29, 2009 What I would like to do is create my own application where I can display the teletext. Stand-alone without any connection to DVBViewer? Is it supposed to receive the original transport stream from a DVB device? Or read the data from a file? Please be more specific. Quote
TommyN Posted August 30, 2009 Author Posted August 30, 2009 Stand-alone without any connection to DVBViewer? Is it supposed to receive the original transport stream from a DVB device? Or read the data from a file? Please be more specific. Well, thinking about it, it does not necessarily have to be stand-alone. What I would like to do is tune my DVB card to a channel and get access to the teletext (I guess I need to interprete the VBI?). I would then programatically change teletext page, read all the text in the teletext page and display in a custom view/window in my application. Does that make sense? Is it perhaps possible to do by writing a plugin to DVBViewer instead of doing it stand-alone? Thanks, -Tommy Quote
Lars_MQ Posted August 30, 2009 Posted August 30, 2009 you could use the COM Interface. The IVideotext.GetPageAsRaw delivers a Psafearray of Byte with the raw ttx Data. It's up to you to interpret the data. Quote
TommyN Posted August 30, 2009 Author Posted August 30, 2009 you could use the COM Interface. The IVideotext.GetPageAsRaw delivers a Psafearray of Byte with the raw ttx Data. It's up to you to interpret the data. Thanks! The interface seems to contain exactly what I need Cheers, -Tommy Quote
TommyN Posted August 30, 2009 Author Posted August 30, 2009 you could use the COM Interface. The IVideotext.GetPageAsRaw delivers a Psafearray of Byte with the raw ttx Data. It's up to you to interpret the data. I downloaded Visual C# Express and had a go at it but I was not able to get it to work properly. DVBViewer starts up and tunes to the correct channel, but I don't get anything back from the Videotext methods. When calling server.Videotext.GetPageAsRaw(201, 0, out t); the last var/out parameter is always nil. Sample code: DVBViewerServer.DVBViewerClass server = new DVBViewerServer.DVBViewerClass(); private void button1_Click(object sender, EventArgs e) { server.CurrentChannelNr = 227; server.Videotext.onDataArrive += new DVBViewerServer.ITeletextEvents_onDataArriveEventHandler(Videotext_onDataArrive) ; textBox1.Text = server.Videotext.GetPageAsHTML(201, -1); object t; server.Videotext.GetPageAsRaw(201, 0, out t); if (t != null) textBox1.Text = t.ToString(); if (server.Videotext.FindPage(201, 1)) { MessageBox.Show("Yes"); } } void Videotext_onDataArrive(int PageNr, int SubPageNr) { textBox1.Text = "Data arrived"; } Any idea what might be wrong? Thanks for your help! -Tommy Quote
JMS Posted August 30, 2009 Posted August 30, 2009 (edited) Actually I don't know the API but from the names of the methods and your code I would guess that you should call GetPageAs* inside the onDataArrive event handler with the parameters it gets - and filter on the page you would like to process. Normally video text pages come by in the data stream so requesting one at a given point would force the application to wait for it. Jochen PS: And by the way it may (?) be a bad idea to access controls from inside the event handler as long as you are not sure that the event producer (i.e. DVBViewer) makes sure that the event is reported on the GUI (main) thread [don't known if this is so but in normal host applications of this kind this is not the case because it makes few sense for the host]. Edited August 30, 2009 by JMS Quote
