avoidz Posted September 3, 2009 Posted September 3, 2009 (edited) Hi, it there a reason why all of a sudden I can't use the cursor arrow keys up/down to change channels anymore? Anyone come across this problem before, or have the inputs been changed in the new version? Using version 4.2.1.0 Cheers Edited September 3, 2009 by avoidz Quote
Tjod Posted September 3, 2009 Posted September 3, 2009 Change: MiniEPG preview: OSD-Up/Down browses the channels, left right the time, OSD-OK switches to the channel. Ch+/ch- and Fav+/Fav- does switch the channel at once now. You can revert back to the old behavior in the options (TV + Radio). http://www.DVBViewer.info/forum/index.php?showtopic=35263 Quote
avoidz Posted September 6, 2009 Author Posted September 6, 2009 http://www.DVBViewer.info/forum/index.php?showtopic=35263 Ah, thanks. I didn't notice that change. It's actually a good change; I prefer it now I'm aware of it Quote
