How to use LME DVB-S Device with Dvbviewer
yes
Hello,
I'm using DM04+ (MV0194 (LME2510+SHARP0194)) DVB-S BOX. Any time I want to change the LNB, to scan the other satellites, nothing happens, scanned at the same LNB, which was used with progdvb.
here is the drivers for tuner and progvb (. device)
http://www.leaguerme.com/USB/download/SHAR...409_x86_x64.zip
Its posible to use .device driver from progdvb to DVBViewer ?
Do you have any idea?
P.S. im using DVBViewer 4.2
  • 4 years later...
I am expreciencing the problem that every time i change the tp i need to reboot DVBViewer
What's the problem?
