israb Posted September 6, 2009 Posted September 6, 2009 Is there a way to have subtitles normally off, but turn them on with the remote? Currently I can see two options: either I do not tick "receive DVB subtitles" in the options in which case how do I turn them on if I need to? Or I tick subtitles on, but then I have to manually select "0" in the subtitles menu to turn them off. I'd like the default to be off, not on, but to be able to turn them on with the remote using the OSD (not options menu....) Thanks Quote
Gioxy Posted September 7, 2009 Posted September 7, 2009 You can link the "OSD show subtitle menu" to a remote button (it's in "Settings / Options / Input / "On Screen Display" section) or, if you want it to stright act a series of actions, you can add a new (multiple) command adding on it all the "OSD-Down" and "OSD-OK" needed to show the subtitle... To know how to, please read this post Let us know... Quote
