pfugl Posted September 15, 2009 Posted September 15, 2009 (edited) I have just installed recording service from scratch. In my recordings directory are a lot of old recordings made by DVBViewer. Is it possible to import them into the Recording service recordings database? I have tried to do a refresh db, which did'nt help. /Peter Edited September 15, 2009 by pfugl
Tjod Posted September 15, 2009 Posted September 15, 2009 Refresh db work with the current Version only if you have Information Files for all recordings. http://en.DVBViewer.tv/wiki/Options_Servic...nformation_File It should be possible with File Info as well but there is a bug in the current version.
Gioxy Posted September 16, 2009 Posted September 16, 2009 And what if one want to add to DVBV DB several (/many) video files not belonging from DVBViewer recording? ...IMO even a little tool (or trick...) for a simple filename only based importation into DVBV DB would be much appreciated...
omnium Posted September 16, 2009 Posted September 16, 2009 ...IMO even a little tool (or trick...) for a simple filename only based importation into DVBV DB would be much appreciated... +1
