René Paw Christensen Posted September 16, 2009 Posted September 16, 2009 What about an option to exclude all channels, except favorites from the EPG. I have organized all the channels as favorites, and never uses the EPG because it is filled with channels which isn't a favorite and I can't watch. René Paw Christensen Quote
omnium Posted September 16, 2009 Posted September 16, 2009 What about an option to exclude all channels, except favorites from the EPG.I have organized all the channels as favorites, and never uses the EPG because it is filled with channels which isn't a favorite and I can't watch. +1 Quote
majstang Posted September 18, 2009 Posted September 18, 2009 Yes, a really good idea! What say you developers? Quote
marty-mcbyte Posted September 18, 2009 Posted September 18, 2009 Hi there, I'm not a developer, but an experienced user... so, take a look at this: EPG Manager the thread is in german, but the program is quite easy to understand... good luck Marty Quote
Tjod Posted September 18, 2009 Posted September 18, 2009 I think for exists every EPG page is a favorites filter. But i recommend using a sorted channel list instead of the favorites. It is possible to use the favorites but you have to change about 20 settings to get everywhere the favorites instead of the channels. Quote
marty-mcbyte Posted September 24, 2009 Posted September 24, 2009 It is possible to use the favorites but you have to change about 20 settings to get everywhere the favorites instead of the channels. hmm... I did most likely 20 settings for one time instead of change 1438 channels I never will look at, every time a newer channellist is present... But this is only my humble opinion... Marty Quote
Tjod Posted September 24, 2009 Posted September 24, 2009 instead of change 1438 channels I never will look at You don't need to sort all channel. Just move the channels you like in a root folder at the beginning of the channel list instead of adding them to the Favourites. Quote
Topogigi Posted October 12, 2009 Posted October 12, 2009 You don't need to sort all channel. Just move the channels you like in a root folder at the beginning of the channel list instead of adding them to the Favourites. The good of favourites is that you can delete the channel list, perform a new scan and find your channels exactly where they were. I know you can update the channellist instead of deleting it, but deleting it and performing a new scan is straightforward and very useful if your provider made many changes.... The bad of favourites is that you have to tweak a bunch of parameters to make all the ensamble work as you like. But you have to make it ONCE.... Quote
majstang Posted October 12, 2009 Posted October 12, 2009 A minor problem as i see is the first channel on the list takes the position nr. 0. My channel STV1 gets position 0 in other words if i place it first in the list. If i want it to have nr 1 i have to place some channel i dont have any use for first in the channellist. When setting up the remote i really dont wanna have SVT1 on button 0. Placing a dummychannel as nr 0 it will show on the EPG...thats why i wanna have the favourite filter for the EPG. Or you could simply fix the channellist itself...the first channel takes position nr.1 and not nr.0 as it is today. Quote
marty-mcbyte Posted October 12, 2009 Posted October 12, 2009 A minor problem ... Don't see it as a problem, see it as a feature... In my favourites-list there is a radio-channel on position 'Zero', so I do have simply access to the prefered radio over the day by pressing '0' - and the other channels are in that order they have to be... (That's also the reason, I don't use a sorted channellist... cause it's not possible to set a radio-channel on first position...!) Marty Quote
Xtro Posted December 8, 2009 Posted December 8, 2009 This EPG Manager does modify the way recording service updates EPG? I have memorized more than 40 satellites with a motorised dish, but I usually only need EPG for 4 or 5 satellites. In EPG Manager I can update only the satellites I wish. My question is if this selected satellites will be the only ones that recording service will update from now on. Quote
