papalos_ Posted September 17, 2009 Posted September 17, 2009 Hello from Greece! I'll try to describe my problem as very simple as i can, because my english are not very good. a. I'm using the latest versions of DVBViewer, dvblink/server and windows7 rtm. b. I've follow all the intrunctions in dvbsbridge pdf file to setup dvbsbridge. c.1. I put the xmltv.xml file(I'm creating xmltv files with tvxb 2.0009) in xmltv folder. When i start DVBViewer it stops sometimes loading at "Create Plugins Menus..." loading bar and it hangs(DVBViewer.exe memory usage about 10MB). 2. If i delete the xmltv.xml file from the xmltv folder, DVBViewer is loading always without problem(DVBViewer.exe memory usage about 75MB). The problem is that when I'm starting dvblink server with xmltv.xml file in xmltv folder, the DVBViewer.exe sometimes hangs(memory usage about 10MB, like when I'm running it alone) and i got No TV Signal message in windows 7 MCE. Also, the DVBlink server application can't terminate the DVBViewer.exe by selecting stop. I close it manually from windows task manager or by restarting PC(sometimes it hangs either after restarting PC and i use task manager to close it again manually) I want to notice here that if i dont' have xmltv.xml file in xmltv folder, everything works correctly ALWAYS, either after standby or hibernate resuming. here is part of my xmltv.xml <?xml version="1.0" encoding="utf-8" ?> <tv generator-info-name="TVxb/2.0009" generator-info-url="http://www.tvxb.com/"> <channel id="101"> <display-name lang="eng">novacinema1</display-name> <url>http://www.nova.gr/eng/tvguide.asp</url> </channel> <programme start="20090917000000 UTC" stop="20090917032000 UTC" channel="101"> <title lang="eng">no schedule</title> <desc>TVxb TERMS AND CONDITIONS: This TVxb guide software may be used by private users for personal use only. Commercial use, sale, or distribution, or bundling of this software with commercial products, is prohibited. The use of TVxb software or this guide to provide a free or paid service is prohibited. The program information in this guide might be protected by copyright and distribution to other people or organizations without the permission of the copyright holders might not be permitted. [ http://www.tvxb.com ]</desc> </programme> <programme start="20090917032000 UTC" stop="20090917045500 UTC" channel="101"> <title lang="eng">CLEANER</title> <sub-title lang="eng">CLEANER</sub-title> <desc>CLEANER : (2007)Duration: 86' : ΤΑΙΝΙΑ : Θρίλερ : Ενας πρώην αστυνομικός εμπλέκεται σε ένα σκοτεινό κύκλωμα συγκάλυψης εγκλημάτων, όταν εξαφανίζει άθελά του σημαντικά στοιχεία από τον τόπο μιας βίαιης δολοφονίας, τον οποίο κλήθηκε να καθαρίσει. novacinema1: Πέμπτη 17/9: : 06:20 : Επιστροφή</desc> <credits> <director>Ρένι Χάρλιν</director> <actor>Σάμιουελ Τζάκσον</actor> <actor>Ευα Μέντες</actor> <actor>Εντ Χάρις</actor> <actor>Ρόμπερτ Φόρστερ</actor> <actor>Λιούις Γκάζμαν</actor> </credits> <category lang="eng">MOVIE</category> </programme> Any suggestion or idea to solve my problem? Thanks in advance!papalos_ Posts: 2 Joined: Thu Sep 17, 2009 5:54 am Private message http://dvblogic.com/phpBB3/viewtopic.php?f=37&t=5361 Quote
