xFucker Posted September 19, 2009 Posted September 19, 2009 I have problem, i just bought CI module for Skystar HD2 and smardtv CAM cryptoworks, but when i start DVBViewer with CAM inserted i can't play any channel(fta or pay tv), when i in settings of DVBViewer uncheck "has CI module" i can play fta tv stations, but for pay stations it says "no hardware available", when i check "has CI module" back i can't play nothing. In CAM menu i see CAM module and my smartcard(working in digital receiver) and it looks like its working, i don't know what to mean. Quote
Andrey123456 Posted September 24, 2009 Posted September 24, 2009 I had the same problem with TT-S2-3200 and IRDETO CAM. I didn't find any solution. May be wait untill External CI option will become a final release, not experimental. Or use some workaround for your problem Quote
pancho88 Posted October 2, 2009 Posted October 2, 2009 I had the same problem with TT-S2-3200 and IRDETO CAM. I didn't find any solution. May be wait untill External CI option will become a final release, not experimental. Or use some workaround for your problem I had similar problem with skystar HD 2 and it was un uncompabitlity issue betwen card and CAM; I solved using a different CAM. Quote
