Disabling audio/video when running minimize
mborkP
I can't find this option in version 4.2.1 There is an option "disable audio/video" under "view" tab but as soon as I change the channel it automatically restores both. As I remember some previous versions of DVBV had exactly what I'm asking for.
Thanks.
Still at the seam place Options > TV + Radio > Disable AV on minimize.
Oh, ok! Thanks B)
