Is it possible?
mborkP
I followed the DVBLink instructions to create 2 instances of DVBV which seems to work ok. There is however some collissions ie. with remote controll, DD audio. Both programs are installed in separate directories however the data directory for both exist in ProgramData/CMVU/DWBViewer. Is there any way to make second instance of DVBViewer to use ie. ProgramData/CMVU/DWBViewer2 folder?
Thanks
