Fabien44 Posted September 21, 2009 Posted September 21, 2009 Hello, Like WMP which provides a tool to create smartplaylists, is it possible with DVBViewer? Example: i want to play the following generated playlist: 2h of music but no pop genre. If not, may i develop that plugin? Thanks, Fabien Quote
Tjod Posted September 21, 2009 Posted September 21, 2009 DVBViewer only support simpel playlist. If you like to build a Plugin and you know Delphi maybe this is interesting: http://www.DVBViewer.info/forum/index.php?...c=18888&hl= http://www.DVBViewer.info/forum/index.php?...c=18506&hl= (http://www.DVBViewer.info/forum/index.php?showtopic=33768) Quote
Fabien44 Posted September 22, 2009 Author Posted September 22, 2009 Could you advise me a rapid tool for Delphi dev? And also, where can i look at a documentation for DVDViewer plugins (how to, framework, api, specific classes, etc.)? I will develop this plugin Thanks. Quote
Tjod Posted September 22, 2009 Posted September 22, 2009 The DVBViewer Pro has two API. The Plugin interface (Members Section > Sources > DVBViewer Plugin SDK) therefor you need a programming language which is able to build real .dll and the COM (Members Section > Sources > DVBViewer Plugin SDKDVBViewer COM Interface) Interface which is accessible from scripting language as well. I'm not a software engineer so my be someone else can help you with the other questions. Quote
