ols Posted September 22, 2009 Posted September 22, 2009 I used to have my DVBViewer setup so when I moved my house to the right of the screen the list of channels would appear instead of having them in a separate window, can anyone tell me what options i need to select. Or point me in the right direction, I have searched the forum for a good 30minutes with no results Quote
Tjod Posted September 22, 2009 Posted September 22, 2009 Options > TV + Radio > Popup Channellist Quote
ols Posted September 22, 2009 Author Posted September 22, 2009 Options > TV + Radio > Popup Channellist thanks so much! also whats the current build? 4.2.1.0 Quote
Tjod Posted September 22, 2009 Posted September 22, 2009 also whats the current build? 4.2.1.0yes Quote
kdk_warhead Posted March 29, 2010 Posted March 29, 2010 (edited) I got the popup to work as well but it isn't as good as in FireDTV Viewer (that is based on DVBViewer). Is is it possible to get it to look like this? Channel icons, channel name, current show, and how long into the show it is (the green bar)... I think it looks great in FireDTV (a scaled down version of DVBViewer for FireDTV) so i think it's strange that i can´t find it. Edited March 29, 2010 by kdk_warhead Quote
Tjod Posted March 29, 2010 Posted March 29, 2010 Use Zappi or DVBViewer Zapper http://www.DVBViewer.info/forum/index.php?showtopic=39911 http://www.DVBViewer.info/forum/index.php?showtopic=24436 Quote
