RC TTS35AI recognized as keyboard in PRO version
vrgulnik
PLEASE HELP! :D
I am using SkyStar USB 2 HD CI with RC TS35AI. Once I "learn" commands in DVBViewer TE which was part of the box everything is OK but when want to "learn" in PRO version - it is recognized as keyboard not WinLIRC (or anything else). How can I check that everything in installation was done correctly? Do you anybody use SkyStar USB + remote control with the PRO version? What InputPlugin do you use?
Thanx
This is correct, it is a HID device.
