roby5 Posted March 23, 2004 Posted March 23, 2004 I need plugin for Multidec application that i will put in the DVBViewer PLUGINS directory and in NEW directory MDPLUGINS i will put Multidec plugins and the can i use Multidec plugins sech --------------- SS2DiSEqC for motor, EPG reader... Like MyTheatre have MDWrapper have to use MDPlugins! ( Source is on the DVBCore website) Can somwhone write this plugin? Thanks!
Klausing Posted March 23, 2004 Posted March 23, 2004 Multidec plugins sech ass SS2DiSEqC for motor, EPG reader For what you need a EPG reader ? the EPG inside is good enough (or not?), SS2Diseqc for motor dish is not recommend!on the DVBCore website DVBViewer don't use DVBCore ! He use Marfis skyavc.ax .There are some illegal possibilitys with such a support which the DVBViewer don't want to support. Steffen
rapper Posted March 23, 2004 Posted March 23, 2004 (edited) You need a [deleted] file in order for the DVBViewer to accept MultiDEC plug-ins, for example YANKS*, but it's illegal to use this kind of Plug-in, NOT IN MY COUNTRY . Edited March 23, 2004 by Oliver
Guest Oliver Posted March 23, 2004 Posted March 23, 2004 And you need to have a look at forum rule no. 7. Bye
