Codecs two problems
Przemek211
I have a two problems with codecs.
There problems weren't seen before reinstall.
I see now that picture on h.264 channels probably hasn't a lot of frames, because in bustling scenes picture is 'jumping'. I tried CoreAVC, Cyberlink, Arcsoft. I off on arcsoft deinterlacing, but still this problem.
Next problem: after few changes of channels i must: rebuild graph, because video is no start (but in 'tray' of program i can see bitrate and other informations).
Edited by Przemek211
I don't know why, but this problem is solved..
But still i can't watching HD channels after change my PC conf (earlier all was good with cyberlink and EVR).
I tried all renderers (also new from beta), all available for me for me h.264 codecs and always on full screen, i can't see all frames, so on fast scenes (e.g. sport), picture is bustling.
First screen (full screen):
http://img196.imageshack.us/img196/9161/asdoq.jpg
EVR losing frames.
Second screen (standard window of DVBV), the picture is good:
http://img196.imageshack.us/img196/2083/asd2ne.jpg
Third screen (not a full screen, but big window):
http://img35.imageshack.us/img35/3906/asd3l.jpg
I see also that on SD channels, EVR has now a problem with OSD. It's not a problem with on DxVA in codec. My graphic card is Palit 8400GS.
come on.
On MPC-HC with his DxVA codec, all is good, EVR after few second of switch to full screen, shows 23.97 frames (on 1080p samples).
Why i can't have it on DVBV?
  • 3 weeks later...
Because you had card not good enough for HD-deinterlacing. Now i bought Gigabyte HD4550 and all is good. HD channels on full screen has 50fps. You can check it on this page: http://www.missingremote.com/index.php?opt...mp;limitstart=1
Moderators can merge my posts. This post is information for other which have similar problem
