DVBViewer Cannot Locate Any Channel
login365
I've attempted a channel scan update on DVBViewer v4.0 to receive some channels that became available a while ago in the UK, however it has wiped my complete list of channels. I've since spent a lot of time trying to re-scan and get my list back, however it would only locate a small number of channels, even after double checking the transponder ini file.
This led me to upgrade to v4.2.1.0, however DVBViewer will not locate any channels now! When I use 'ScanChannelsBDA_UK', it locates all the channels and Media Centre will also scan and tune to all the channels, but DVBViewer wont!.
I've spent a lot of time fiddling with the offset, but with no luck.
Can anyone help? My spec is:
Windows Vista Ultimate
Hauppauge HVR 1300
DVBViewer 4.2.1.0
Live in UK near Winter Hill
Cheers,
Mike
