[Question] DVBViewer + switch Diseqc
cachiputi
Hello Comrades!
I have a question, DVBViewer Pro 4.2 is compatible with a Diseqc switch?
Because I have a satellite Hispasat oriented and want to put another antenna oriented Astra and Hotbird. I connect the 3 LNB to Diseqc switch to the 3 satellites are on the same wire.
DVBViewer Pro 4.2 supports Diseqc switch?
Edited by cachiputi
DVBViewer supports DiSEqC 1.2 but not all cards are compatible.
http://www.DVBViewer.com/griga/TransEdit%2...SEqC.html#Title
Thanks for the information!
My card is a Hauppauge WinTV-HVR-4000
You know if this card supports Diseqc 1.2?
Thank you!
EDIT: My card only Supports DiSEqC 1.0. Is compatible with DVBViewer and its protocol ?¿?
Edited by cachiputi
