[Question] Change channel from Streaming
cachiputi
Hello Comrades!
A few days ago I started to try the NetStream pluguin. I managed to send the signal via streaming from (Server, WinXP) DVBViewer Pro 4.2 (Client-Mac OSX) VLC.
The image and sound is perfect. But I can change channels from VLC, wanted to know which way is to change channel without having to enter the server. Doing it from the client.
Thanks, I await your response!
NetStream plugin streams the channel which is live playback in DVBViewer.
To change the channel you have to change the channel in DVBViewer.
I recommend using the Recording Service instead of the NetStream plugin ther is it possible to change the channels via web interface.
http://en.DVBViewer.tv/wiki/Category:DVBVi...cording_Service
Thanks, sounds interesting!
I downloaded the program and installed it on the server. But I can not enter my MAC OSX desdde Webinterface from the same server, if and been able to enter the Webinterface.
Sincerely, nose so badly ago.
I was already using a program called TeamViewer, it appears that use the same port, so you disable TeamViewer tube on the server.
