empty channel in list
Przemek211
Hi, i'm going to build channel list with empty channel
e.g.:
57. zdf
58. ard
59. empty - which is no viewed by down-up channel switching
60. zdf hd
if it isn't possible please tell me
and next question: in DVBV 4.2.1 when i'm switching channels up-down i must after click enter. (i can change it in preferences of DVBV, but then channels are changing also in OSD. I'm using XIC3 OSD.
Edited by Przemek211
No, a gap in the channel numbers is not possible.
If you use a new version you should read the changelog:
http://www.DVBViewer.info/forum/index.php?showtopic=35263
Change: MiniEPG preview: OSD-Up/Down browses the channels, left right the time, OSD-OK switches to the channel.
Ch+/ch- and Fav+/Fav- does switch the channel at once now. You can revert back to the old behavior in the options (TV + Radio).
thx for your reply. I added my idea in suggestions forum
I have other question about Input menu.
Before reinstall i had a key which was zoom a picture (i'm using it for 4:3 programs with letter-box).
Now, i can found only dynamical zoom (i must hold key to good zoom). Earlier i had a recalls (which are still in zoom menu). Now i can't find this functionallity from key (only menu open or dynamic zoom).
