Kiwi_Tim Posted September 30, 2009 Posted September 30, 2009 Hello, I'm fairly new to DVBViewer. I have played around with SageTV, but found it to be unstable on my system, whereas DVBViewer is as solid as a rock. One plugin for SageTV is dvbe4sage (http://sourceforge.net/projects/dvbe4sage/), which enables the simultaneous recording of multiple channels from a single tv tuner. It creates several virtual tuners that behave like another physical tuner. It works withDVB-S and DVB-T. Is there any plugin available that will do something similar for DVBViewer? Many thanks, Tim Wellington, New Zealand Using DVBViewer with Nova-S plus and Hauppuage HVR-3000, WinTV-CI XP Pro SP3 Quote
Tjod Posted September 30, 2009 Posted September 30, 2009 With DVBViewer you can record per tuner all not encrypted channels from one frequency simultaneously without plugins. Quote
Kiwi_Tim Posted September 30, 2009 Author Posted September 30, 2009 With DVBViewer you can record per tuner all not encrypted channels from one frequency simultaneously without plugins. That's great news. I'll give it a try! Many thanks, Tim, Wellington New Zealand Quote
