How to get DvbViewer 4.1.1
Bomber76
I want to get version 4.1.1 but it is not found in member sections
4.2.1 has some problem that i cannot watch several channels. :bye:
However, i don't want to install beta version.
Any Help? Thanks.
If a version is not in Members Section it is not possible to get this version.
please explain
please explain
thanks for your reply.
Um... the sound of those channels is okay.
screen is always black with probably 1 second video flashing.
bottom left corner of DVBViewer, near the channel name, it got a "*".
But i don't have any problem in 4.1.1.
Also, DVBViewer Recording Service is upgraded from 1.5.0.2 to 1.5.0.31.
As far as I know this mean the CAM is not able to decrypt the channel.
Please post you support.zip
I will have a look on that.
thank you
Name">AmazePc DMB8GL5</entry>
Quite interessting, this device does seem not have any CI so there is the solution. No CI, no CAM, no decryption.
I have the same problem. In DVBViewer 4.2.1 I can`t watch some channels. I have SkyStra HD2 + CI + CAM and Technotrend TT-3200 + CI + CAM.
I wrote about my problem here:
http://www.DVBViewer.info/forum/index.php?showtopic=36513
I`m watching encrypted channels but I can`t watch some encrypted channels like TVN, TVN Turbo....
With DVBViewer 4.1.1 I can watch everything.
How is your problem related to a device without a CI or CAM? Please DO read more careful. :bye:
Sorry. I think that my problem is similar.
I thougt that this is a dvbvierwer 4.2.1 problem.
I thougt it dosen`t matter if I watching FTA or encrypted channels.
