Lost recroding i Recording Service
McenterFreak
Why is this SW so unstable?
I have installed Recording Service on a máchine with two FireDTV boxes, using Canal Digital on Thor 5
I can tune tune both SD an HD channels, but i am never shure if it works. This evening i tried to record Dark Knigth on Canal + HD, but al i got was a 17 gbyte file witouth any video, only audio :)
I know i should use the support tools, but on which machine, server or client?
Needs Canal+ a cam? Maybe its a cam-problem.
The machine that did the recording (Server).
And it would also be a good idea to activate log file and extended log file for the recordings. And post also this logfile from a recording thats not correct.
Can you play the recording with another software?
It did the trick, Thanks!!
You are welcome! Funny when DVBViewer cant even play its own recordings and the solution spells an another player :( We are a growing crowd having this issue and hopefully, if some more people reporting about it, they cant deny the need to have it fixed.
Edited by majstang
